Hello @banksysan,
I hope you're doing well. Thank you for all of the images. They clearly show what's wrong. In the free version of Fusion, the board outline must only be on the positive x and y axes. In other words, the bottom left corner of your PCB needs to be at the origin. It's the only configuration that will work in the free version.
Once you adjust your board outline location you'll see that you'll be able to place parts within it.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
