updating library causes removal of all values
AlexandrGUR2M7
AlexandrGUR2M7
Hi!
Please help!
Facing really annoying problem, Im added new resistor package to the library, and trying to add it in to schematic, a dialog appears:
"A different version of device set R is already present in this file and needs to be updated"
Pressing "NO" does nothing, but pressing "YES" adding needed component with removal of all R values in entire schematic.
button "Update design from all libraries used in design" also removes all values for changed device.
jorge_garcia
Hi @AlexandrGUR2M7 ,
I hope you're doing well. The values are likely not gone they are just not seen . Try using Autoposition attributes set to Restore Default. Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
AlexandrGUR2M7
Hi Jorge, thanks for repply, I tried Autoposition attributes, it restore designator and value location on schematic, but not restores blanked value of changed resistor. Please, look at attached video.
jorge_garcia
I hope you're doing well. If you can look in your resistor device and check it's attributes. If you have an attribute called VALUE and it's empty, please delete it. That's what's causing the values to get cleared when you do the update. Check the attributes specifically of the package you are updating to.
Best Regards,
Jorge Garcia
AlexandrGUR2M7
Thank you Jorge! that was the cause.
