Update on diagonal cross-hatching of polygons? Feature request!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This topic was discussed in a forum post from almost a year ago. is this on the future features list? One of the comments was that 45-degree hatching it wasn't functionally different from 90-degree, but that's not accurate. For controlled-impedance situations, where the hatched pour is the reference plane, it matters a lot. Imagine that the traces are running left-right, i.e. 0 degrees; if the hatching is 0 and 90 degrees, you'd have some traces with a hatch strip under them, and others with mostly no copper under them, leading to very different impedances. The 45-degree hatching is therefore commonly used in this situation. Why not just use a solid pour in that case? If the design is a flex circuit, a solid pour is often too stiff for the intended bending of the flex.
So, this is a plea for that feature to be added!
Scott
