Unable to move components into inserted DXF board outline
- Mute
- Permalink
- Report
I'm able to insert a DXF board outline (created in Adobe Illustrator), and the layout viewer appears to recognize the shape as a closed polygon (inside is darker than outside), but I cannot move any new parts into the board shape, nor can I move a component once it is in the board area (placed before the DXF is inserted).
For the component that is within the the board outline space, I'm getting "Smd-Spline" DRC errors for every pad, and "Edit rule" for those errors pulls up the Copper/Board outline, which is 0.01 in.
I'm able to draw a new board outline with the line tool and move parts in and out of the board without issue, so I don't think it's a DRC issue (I've also used this DRC ruleset many times in the past without issue, at least with Eagle 9). I've also tried loading the default ruleset in and have the same problems.
Additional things I've tried is changing the dimension line width (I didn't think this would be it, but tried anyway).
I'm trying to transition to Fusion after being a long time Eagle user, so I'm not sure if there's something I'm doing wrong here (using Place > Insert DXF/DWG). One thing that's strange is I cannot change the board outline object's layer once it is placed. I'm not sure if that's any sign of an error with the import. I have tried inserting just a simple circle DXF (without the 3 notches) and that worked normally, so maybe the notches are creating a error?
I really don't want to have to transition this design back to Eagle 9, but I'm also on a bit of a time crunch and I need to be able to import a custom board outline.
Any ideas for things I could try or do differently?
