Unable to create polygon from board outline
projectHFRGQ
projectHFRGQ
I'm trying to create polygon from board outline but there's no "convert to polygon" option after right click (I guess after some updates) and "Polygon Pour from Outline" makes nothing. Should I do something else before making polygon pour from outline command?
Edit: I've found out that I'm unable to make this polygon only when the PCB is a circle.
pieterjanvandemaele
This is a current limitation of the convert to polygon option. We recommend to use 2 half arc's for the board outline to work around this issue.
