Trying to create a electronics drawing
FransUrbo
Message 1 of 11
FransUrbo
I'm trying to create an electronics drawing from my design, but there's nothing "in it"!
I've been following the guide, but it's just blank.
Looking at the file viewer and the sheet, it does look like it's something there, but can't actually see or do anything. Not sure what I've missed..
I'm running MacOS Monterey (latest update) and latest update of F360 (it updated yesterday).
Replies (10)
Message 2 of 11
ajay_krishna_t_s
Hi
Thank you for reporting the issue. Are you experiencing this with a particular dataset? Could you share a recording of the steps on how you are creating the ECAD drawing?
Ajay Krishna
Software QA Engineer
Message 3 of 11
pankaj.km
Hi FransUrbo,
Thanks for reporting the issue.
It seems the view is still there in the canvas but due to some rendering issue its not visible, as we can still see the views in thumbnails(highlighted in red).
Can we just try toggling any browser node to see if that makes the view visible?
Please let us know if that works.
Thanks.
Message 4 of 11
FransUrbo
I have, that does nothing.
I've tried this several time, create a drawing from an electronics project. Toggle the browser nodes, create a drawing from the project, and/or from the schematic. On several different projects. They all end up the same - empty view, but "something" in the thumbnail.
Message 5 of 11
ajay_krishna_t_s
Hi @FransUrbo
Thank you for the reply, I noticed that you are on MacOS Monterey, while this OS was not on the supported list since 2024 - Novemeber. So I request you to update to the latest OS and see if that fixes the issue. Thank you!
Ajay Krishna
Message 6 of 11
FransUrbo
If I could upgrade, I would have..
This is the last Intel Mac's, so unfortunately I'm stuck with Monterey until I can afford a new one..
So are you saying this is because of Monteray, and I'm the only one having this issue?
Message 7 of 11
ajay_krishna_t_s
Hi @FransUrbo,
I have tried to reproduce this with the latest MacOS versions, but was not successful. You are the first user to raise this concern. Even for the development, Monterey OS was not on the supported list since 2024 - Novemeber. Can you check if you are observing the same issue with the mechanical drawings?
Ajay Krishna
Message 8 of 11
FransUrbo
Actually I do, I didn't think of checking that.
But I just opened one that I made a few years ago, that I haven't opened since '22 (!).
The thumbnail is fine, and I *know* that it was ok when I worked on it (I sent it to someone to have it manufactured!), but now it just opens "empty".
Message 9 of 11
ajay_krishna_t_s
Hi @FransUrbo
I see that the issue that you are experiencing is not specific to ECAD drawing. As I mentioned earlier, for unsupported OS, we can not do anything. You can find the minimum system requirements for Fusion here - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement... .
Ajay Krishna
Message 10 of 11
FransUrbo
Yeah, until you change that again 😞 😞 :(.
Dang I hate this "it's a few years old, so throw it away and buy something newer" mentality 😞 :(.
Message 11 of 11
obulesub
Hi @FransUrbo,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Obulesu | Community Manager
