Toggle units - shortcut?
oleksandr_velihorskyi
Dear community,
how can I now toggle the units between mm and mils with some shortcut hotkey? Is it possible? for now I have used G and then selected mils or mm in grid setting. But it is not so convenient. ULP script and hotkey? SET UNITS MM doesn't work...
chuck_toddN7PTC
Here is one way to get it done. Create shortcuts for each unit. See highlighted rows in image below.chuck_toddN7PTC_0-1744743313044.png
BR -Chuck
Chuck
Evert_2N3055
I made a simple ulp to toggle trough the grid unit's.
Save the below ulp to your local drive.
Make a new shortcut in Fusion with the a key combination of your choice, enter as command Run c:\yourpath\togglegrid.ulp
Note: After running the ulp you see the units change only after moving your mouse a bit.
I have tried something similar, but it looks like "unit" is not supported. I have faced the error "unknown identifier unit" with your ulp script too.
