Text isn't correct height
silvio3105
Message 1 of 8
silvio3105
so I made my first PCB in Fusion 360. For silkscreen text I use 27mil(0.7mm) text height and 6mil(0.153mm, 20% text ratio) line width.
Today I received PCBs and silkscreen text(for designators) is unreadable. Even I who made the PCB cannot read some designators.
Since at work I work with same silkscreen text(27mil height and 6mil stroke, but in Altium) I was like "wtf??". PCBs are from JLCPCB, like mine.
So I went to Fusion and 0.7mm(27mil) text height is not 0.7mm - it's 0.635mm.
Really?
As usual, here's video
https://youtu.be/RfN6IxKYqfY
Enjoy!
@◘EDIT:
Okey, I see where's the problem - line width.
But why silkscreen is so unreadable on my PCB? Same height, same stroke, same boardhouse
Replies (7)
Message 2 of 8
silvio3105
Message 3 of 8
jorge_garcia
Hi @silvio3105,
Board houses typically have minimum line widths. In your case this text has a line width of 5 mils approx (27mils x 20% ratio = 5.4 linewidth). Not all board houses can handle that, I generally like to stick to a line width of 8mils if I have enough room.
If you check your Altium board it probably has wider line widths.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 4 of 8
silvio3105
I use 27/6mil as at my ex job.
Only difference is font. Why font cant be changed?
Message 5 of 8
jorge_garcia
Hi @silvio3105,
I hope you're doing well. You can change the font select the text, set the font to custom and then you'll be able to select any of the fonts you have on your system for your board. Bolded or thicker fonts work better obviously.
Did you use the same boardhouse at work compared to at home? If you did then you should expect similar results but if you used a different boardhouse then that might explain the difference in silkscreen.
Best Regards,
Jorge Garcia
Message 6 of 8
silvio3105
Yes, JLCPCB.
Will be custom font same as vector font on PCB in real(in production)?
As far as I know, vector font is must because of gerbers.
Message 7 of 8
jorge_garcia
Hi @silvio3105,
I hope you're doing well. In Fusion 360 the requirement for vector font in the gerbers has been removed. In Fusion, all the fonts will render correctly in the gerbers.
Best Regards,
Jorge Garcia
Message 8 of 8
silvio3105
Well, then a lot of re-work is in front of me 😄
Thank you.
