Test and Ref layers
Test and Ref layers
silvio3105
Test and Ref layers
silvio3105
Can someone explain what should I put into layers Reference(49-50) and Test (37-38)?
I have fid markers(my own lib) but they are only oepn copper. What should I put into layers 49-50?
Same for test points. Open copper with circle in silkscreen layer. Should I redraw those footprints to layers 49-50/37-38?
Also, I don't see ReferenceLC/ReferenceLS layers, only Reference layer(#49). Layer #50 is missing.
jorge_garcia
Hi @silvio3105,
I hope you're doing well. These aren't used by Fusion Electronics by default so you can bend them to your will and use them for whatever application you deem fit.
I know it's not much of an answer but it's the truth, not all of the default layers have a predetermined purpose or one that we use by default.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
Okey, but in EAGLE case, what user will draw into Test layer? Draw footprint(open copper) or just add little dot/+ mark in center of test point(drawn in top layer)? Same question for Ref layer
jorge_garcia
Hi @silvio3105,
The easiest answer is to draw whatever you want on them. Honestly you can use them however you want. If you are making a test jig for a PCB then you can draw jig specific info that layer. If you have specific internal part numbers that might be a good candidate for the reference layer.
For any layers that we don't use by default you can really interpret them to whatever use you deem best.
Best Regards,
Jorge Garcia
