Support for spacemouse in fusion electronics?
chris.eganY2EK3
Message 1 of 14
chris.eganY2EK3
I use a space mouse a lot for general CAD design, but for whatever reason it does not work in the electronics workspaces. Obviously there is no rotate, but it would be awesome to gain support for pan/zoom to make it easier to move around a PCB when zoomed in.
Is it possible that this does work and something is wrong with my drivers/setup/configuration, but nothing I've tried makes it work so far.
Replies (13)
Message 2 of 14
ritste20
I use my space mouse every day for 3D modeling but I can't say I've ever tried it in electronics. I will have to see if it works on mine.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 3 of 14
jerry_gabrie
Does anyone know how to turn on the pan feature in electronics? I use my spacemouse for everything and I would like to also use it for fusion360 electronics. I can only zoom in/out.
-JG
Message 4 of 14
chris.eganY2EK3
Until Autodesk does something you can't. Fusion electronics flat out doesn't support it right now.
Message 5 of 14
CBL_CP
Yes, my company made me switch from Altium to F360 back in 2020. It was a really bad year. I am still struggling with getting productivity up. I am really missing spacemouse support. I am struggling on so many levels to understand why on earth this has not been implemented already, along with other things eg. via stitching. 🙄
Message 6 of 14
jerry_gabrie
Message 7 of 14
jorge_garcia
Hello @jerry_gabrie ,
I'll add your voice to the existing ticket for this feature. In order to pan, you have to do a middle-mouse button click and hold. Whatever button you configure on the Spacemouse to represent a middle mouse click is the one you would use to pan.
There are several ways to do via stitching in Fusion Electronics, you could do it through a ULP or activate the VIA command set the name by typing 'PUT_NAME_HERE' followed by enter. This will name the vias to whatever net you want them to connect to, every time you click to drop a via the via will automatically connect to the net named PUT_NAME_HERE.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 8 of 14
jerry_gabrie
Thanks for the tips Jorge.
On your via naming tip. I tried it and it wouldn't recognize the 'option'.
Here are my steps:
First Method:
1. Activate via command
2. Start typing the net name "GND" - it brings up the grid settings panel right after pressing g - since 'g' is the hotkey for opening the grid settings
Method 2:
2.Press '/' to activate command line mode
3.Typed GND followed by enter
4. Then I get an error window on the bottom right saying "Invalid option: GND"
Let me know what I am doing wrong. This would be a great feature to speed up via stitching.
-JG
Message 9 of 14
ritste20
Try using single quotes instead.
Steve Ritter
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 10 of 14
jorge_garcia
Hi @jerry_gabrie,
I hope you're doing well. Use option 2 but like @ritste20 mentioned you need to put the name in single quotes then press enter.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 11 of 14
jerry_gabrie
Thanks guys, it worked! @jorge_garcia @ritste20
-JG
Message 12 of 14
chris.eganY2EK3
One more request to please implement this. I am so used to using the space mouse in fusion that I consantly reach for it in electronics designs and get angry that it doesn't work. I have a whole macropad designed around the space mouse for keyboard shortcuts, including electronics specific ones, and it's annoying to not be able to move around the window with my hand already there.
Message 13 of 14
jorge_garcia
Hi @chris.eganY2EK3 ,
This is almost at the finish line, just hold out a little longer. 😁
Best Regards,
Jorge Garcia
Message 14 of 14
chris.eganY2EK3
Figured I would post some appreciation for once, because FINALLY, the spacemouse works in the electronics workspaces.
