Suggestion: Upgraded Properties Panel
chuck_toddN7PTC
chuck_toddN7PTC
When selecting objects on the 2D pcb to be able to see all the columns in the selected objects area of the properties panel you have to extend the panel out as shown below.
It would nice to have a slider at the bottom of the selected objects area to scroll left and right the be able to see the columns while leaving the properties panel the normal size. As I tried to show in the image below with the red rectangle.
BR -Chuck
Chuck
jorge_garcia
Hi @chuck_toddN7PTC ,
It's a little hidden but if you hover over that bottom edge that you indicated, a scrollbar will actually appear and you'll be able to scroll. I just tried it and it worked for me.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
NShah101
Also for another approach, you can hold down "Shift" and use the mouse scroll wheel to do horizontal scrolling.
