SPICE simulation. Can not setup voltage source
arsvivendi1234
Observer Observer
arsvivendi1234
Observer
Observer
When running a SPICE simulation in Fusion 360 (Operting point) all Voltage is 0 Volt.
When trying to setup analog voltage source the following error appears:
You must select a part with SPICEPREFIX attribute value of V or I to use this feature. Use MAKESPICE to make changes.
I do not know where to find MAKESPICE or how it works.
Can you help me with this issue?
Thanks in advance.
Arnd
jorge_garcia
Hello @arsvivendi1234,
I hope you're doing well. Have you place a voltage source from the ngspice-simulation library? The error would seem to imply that you don't have a source in the design to stimulate the circuit. I would start there, the error is a little misleading since you don't usually access the MAKESPICE command directly.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
arsvivendi1234
Observer
Observer
Hello Jorge,
the voltage source from the ngspice-simulation library works.
Thank you for the advice!
Best Regards,
