Share Link
Share Link
r.cowburn
Share Link
r.cowburn
Hello.  I have an 8 layer PCB design and I'm trying to share with external collaborators using the Share Link function.  The schematic renders nicely but the layout only contains 4 of the copper layers (top, bottom, route2 and route3).  My original design also uses route4, route13, route14 and route15, which are not visible in the shared render.  Any idea how to get it to include all of my layers in the Share Link?  Thanks.
jorge_garcia
Hi @r.cowburn,
I hope you're doing well. I've reached out to our developers to look into this. Let me know if there's anything else I can do for you.
Bets Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
yqliu
@r.cowburn , I tested a 8-layer board and all of the layers are visible. If you can share your pcb or the link, it will be helpful for us to look into the issue.
yqliu
Thanks for sharing the link to me, @r.cowburn . You have discovered the reason - it's not because the inner layers are invisible, but because the polygon pours are not supported in the web viewer, even if they are on top and bottom layer. Unfortunately for now there is no good solution to do it. We will see if we can support it in future.
kterryTYYYC
I just ran into this problem myself. Any update on this? I shared a link with a customer but they do not see the copper pours.
jorge_garcia
Hello @kterryTYYYC ,
I hope you're doing well. I can reproduce this, I'll pass this along to the developers in charge of the online viewer.
Best Regards,
​Jorge Garcia
