Several application errors
Message 1 of 11
When I want to move a group of elements I choose the "select" tool, unfortunately I often have to select 2x, because the first time is not checked.
In the program settings I have increased the contrast of the selected elements, (I marked "high contrast" and increased the slider to 3/4) everything is ok, but after a while the settings return to the default, although when I go back to the settings everything is well set. After clicking only OK everything is ok again - for a short time.
On one monitor I have a schematic file, and on the other PCB, when I choose the option of highlighting an element / path, the selected element on one screen is marked, and on the other randomly, sometimes, I move the cursor to the other monitor, the selection disappears.
Replies (10)
Message 2 of 11
I found more problems. I finished the project, I clicked on "Errors" showed me that I had 2 errors - "airvire", although it was connected. Ok, I deleted the path and created it again. I was very surprised, because instead of 2 mistakes I already had 4. I removed this path again and put it again, this time there were already 6 errors.
Message 3 of 11
ESCAPEKIT
Yes, this happens. It had happened to me already in Eagle so I just verify visually that it is in fact connected and I approve the error so it doesn't show anymore.
Message 4 of 11
Another problem is the use of import-bmp.ulp, from what I see in the forum other people do not have a problem with it, every time I want to run the script I get the message: "error in constant". I downloaded the same script from autodesk website, to no avail.
Message 5 of 11
jorge_garcia
Hello @Anonymous,
I hope you're doing well. Is it able to open at all or you just get that error right off the bat? Could you try it in a different design to see if it behaves the same way?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 6 of 11
hmmm weird, it didn't work on Friday, now it seems that it's ok
Message 7 of 11
I found another 2 problems.
First with generating gerber files. I made a very simple adapter.
the preview of the generated gerber file looks like this:
next gerver viewer:
another problem concerns the 3D preview, it looks like this:
Message 8 of 11
jorge_garcia
Hello @Anonymous,
I hope you're doing well. What gerber viewers did you use? Something looks definitely off there. I'll ping the developers on this for review.
Best Regards,
Jorge Garcia
Message 9 of 11
I use gerbv, it never let me down, the second picture is from the preview at jlcpcb.com. I noticed that sometimes when I restart the program (fusion) the problem disappears, but not always.
Message 10 of 11
jorge_garcia
Hi @Anonymous,
I hope you're doing well. I don't trust the jlcpcb.com preview at all, I've had to deal with a lot of issues with them. I've worked with gerbv a lot and even though it's lead me astray a couple of times, it's very solid and I do trust it.
Would you be able to share the gerbers for review?
Best Regards,
Jorge Garcia
Message 11 of 11
ampio
I was able to call this error again, in the attachment I send incorrectly generated gerber files.
