Set font size of component name for every component on board
jeremiahrose
jeremiahrose
Hi there!
Title says it all. I'm in need of a command that sets the name font size of every single component on the board at once (doing them manually one-by-one is infeasible).
Any suggestions?
HelenChen-AutodeskQA
Hi @jeremiahrose ,
Thank you very much for asking.
You could try to filter out all the attributes you want to change font size from the Design Manager, and then change the font size in the Inspector for all of them at once.
Hope it helps.
Please feel free to let us know if you need our further assistant. 🙂
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
rbkyorem
1.Filter what you want to make changes on.
2.Select whole board so you select what you have filtered.
3.Now type change on command line and choose what you wanna change. If you know what to change you can type
Example: Change layer. In your case Change size is probably what you need.
4.Right click on screen and click change group.
