Selecting component / device set via SCR command
bast2R8CK
bast2R8CK
I use an ULP script to generate a SCR script that applies changes to all attribute sets / technologies in a library.
That works fine as long as the library only has 1 component / device set: I can output the "package" command to select a variant and then do things with the "technology" command etc.
But when I have more that 1 component / device set, the SCR script has to select the active component / device set first, before outputting the "package" command.
So my question ist: What is the SCR command to select a component / device set? I haven't found any information on that so far.
bast2R8CK
Oh, well ... I just found out — it's "edit"! 🙃
