Schematic Drawing
Schematic Drawing
dozerdroid
Schematic Drawing
dozerdroid
Hi Folks,  I've been a F360 user for numerous years but just recently tried out the electronics portion since I have to turn a small circuit board to two ... I am correct that there is still no way to output a schematic or board layout as a drawing with frame and title block for documentation ?  If this is correct could someone from AD give a hint if this is on the short term radar ?  If not I will have to skip using F360 for this, thanks for the heads up.  K
jesper8W75R
You can absolutely do this.
Using the "frames" library (from Library.io), you can add a number of different frames, just like you do with components.
dozerdroid
Thanks for the reply, yes I later found the frames library which will do for now. I guess what I was originally hoping for was some additional eagle integration from AD down the road something similar to what is done with the 2D drawing.
