Does the "version history" feature of Fusion 360 apply to electronics designs, or only to mechanical drawings?
Can you show me where to find it please?
Oh, I found it. Thanks!
It's the same with mechanical docs:
The multi-document nature of the Eagle design schema makes version management quite awkward. It is clunky (and error prone) to rewind to a previous coherent version set because you must unwind each individual document to the known good version, manually drop the links in the master document, and re-link to the new latest versions.
At some point, when the app is stable enough to consider non-essential UI cosmetic changes like this, it would be valuable to have a single-select drop-down in the master document to wind back all the documents in the set to a known consistent previous version-set.
I am also keeping my fingers crossed for a day when the individual document scheme is dropped, in favour of a more holistic DB schema that maintains all 3 design elements together as a single document and broken annotation warnings are a thing of the past. Pipe-dream?
Hi @jonrbloom ,
I hope you're doing well. Thank you for the feedback, I'll pass this along to our developers.
Best Regards,
