Route Command no longer functions properly
daleEDTTN
daleEDTTN
When using the route command, typing "route 0.4" normally results in a 0.4mm trace, but now just results in whatever the previous trace width was set to.
constantin.popescuXD3CL
Hi @daleEDTTN,
Thanks a lot for reporting this issue to us. I have tried and I can see the problem. This issue is caused by the latest updates to route Trace Width selection behaviour and was unfortunately missed by us. I have fixed the issue and the fix will be available in the next Fusion update. In the meantime you'll have to use the Route command panel to select the trace width.
I hope this helps.
Kind Regards,
Constantin Popescu
Principal Software Engineer
daleEDTTN
Thanks so much Constantin!
HelenChen-AutodeskQA
Hi @daleEDTTN ,
Hope all is well.
Great news that the fix is ready in the latest Fusion Production build 2601.0.90. Could you please upgrade to latest Fusion version to have a try? Looking forward to your feedback.
Hope you have a great day.
Best regards,
Helen
Helen Chen
Principle QA for AutoCAD Windows
