Rotating board also change orientation of idents (part name)
anuradha.bodke
anuradha.bodke
Hello Team
I using Fusion 360 electronics
I finalized pcb layout,  as drill drawing was not generated in fusion , all the time I have to shift to Eagle
In Eagle for panel creation if I rotate pcb by selecting all , orientation of idents are also change
if  I already finalized the pcb layout, after panelize,  I have to check and modify all idents again
If any one have solution for this , Please Share
Thanks in advance
Anuradha
jorge_garcia
Hi @anuradha.bodke ,
 I hope you're doing well. There are a couple of things that fit into the symptoms you are describing. My first thought is that if you are going to rotate the text and you want the orientation to stay consistent make sure to check the spin flag for all of your test. This is easiest to do with the inspector and selection filter. Set it to only select the text then in the inspector you can adjust the spin parameter for all of the texts.
That should solve the issue for you.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
anuradha.bodke
Hello Team,
I want orientation of Name of component remain same
and as per suggestion, in selection filter Name option  was not appear
so I have to check spin option in device properties
doing so in 3d pcb,  setp file of component rotate (mismatch)
Please share if I do anything wrong
Anuradha
jorge_garcia
Hello @anuradha.bodke ,
The spin setting is controlled in the 2D PCB not the 3D PCB. So go into the 2D PCB and adjust the spin flag. When you push to the 3D PCB it will appear correctly.
Best Regards,
Jorge Garcia
