I have two large PCB designs, built entirely in Fusion 360, that I wish to merge into one new board. I have tried the following, with no luck:
- Insert Schematic: This feature imports the schematic properly but doesn't bring in the board layout - it just scatters the inserted components across the PCB canvas.
- Insert Electronic Design: This gives exactly the same results as Insert Schematic. Component layout is not preserved.
- Insert 2D PCB: This doesn't work, and gives the error "A 2D PCB only electronics design can't be inserted into a svnchronous proiect. Please link a corresponding Schematic to your electronics design file."
So my question is simply whether this is possible in Fusion 360 today? I found this post from 18 months ago saying it doesn't work and it's planned, but couldn't find anything since. There is also a product update announcement video from a year ago showing the Insert 2D PCB feature working, but I can't replicate whatever is happening there.
Any help is appreciated! If I have to re-layout one of the boards onto to other board, this will be DAYS of redoing the same work because of a limitation in the software.
Josh
