Problem with integration between Fusion and Eagle
fefegarcia_1
fefegarcia_1
Hi!
I don't know if it's a known issue but I found a problem while moving parts with mount holes in Fusion.
After move the part the previous mount holes are not deleted when the project is pulled back to Eagle. Also after push the project back to Fusion the holes remains.
Here some screenshots:
After move part in fusion.
After pull back to Eagle.
Ater push back to Fusion.
Best regards.
jorge_garcia
Hi @fefegarcia_1 ,
Thank you for posting this.
@HelenChen-AutodeskQA I think this is a known issue, but could you confirm? If it's not could you make a ticket.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Hi @fefegarcia_1 , @jorge_garcia ,
Sorry for any inconvenience. I could confirm that this is a known issue in EAGLE 9.6.2.
 @fefegarcia_1 , do you mind to use Fusion 360 directly for this case? If you New Electronics Design in Fusion 360 and then reference to the schematic and board file, and then View 3D PCB from board file and move part as you want, you will not have this issue in Fusion 360.
Hope it helps.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
fefegarcia_1
Hi!
Thanks for all answers.
I have some difficult of adaptation to work with electronic design in Fusion.
For now I can move the part in Eagle or delete the holes after move in Fusion.
Best regards.
