Problem importing .lbr file generated by https://www.ultralibrarian.com/
josephficara
josephficara
Greetings,
I attempted to generate a fusion 360 compatible library using Ultralibrian.com, for the Analog devices part LTC4376CDHD.  When importing the resulting .lbr file into Fusion360 I don't see the symbol, footprint or 3d models, see the attached ScreenShots.zip file.
I also tried using the export option to export to a Eagle file, the resulting .scr file failed to import using the automate step with the error "Use the PACKAGE command to select a package variant first!"
This is the link I used to generate the file lbr and scr files:  https://app.ultralibrarian.com/details/4fc8289e-38cd-11ea-a124-0ad2c9526b44/Analog-Devices-Inc/LTC43...
I have attached the resultant lbr and scr files in the zip file LibraryFiles.zip
Thank so very much for your assistance.
josephficara
I spoke with Fusion 360 Support. The issue here was importing the .lbr file directly from the library manager while in the schematic vs creating a new library and uploading the library file. Creating a new library and uploading the library file worked properly and I am now able to use the component in my schematic.
