printing pcb layers without component origin cross
LukasDebe
LukasDebe
I am trying to print pcb layers and then manufacture them myself for that i need the layers printed to a film.
I can not print one layer without the component origin cross which is really frustrating since idk what i am missing it should not be something that should be printed and i cannot find a setting to deactivate the cross.
Is there some setting im not aware off or is there a fast workaround ?
I have added two screenshots. I only selected the boardoutline layer and the copperbottom layer before the print.
Best Regards,
Lukas
jorge_garcia
Hello @LukasDebe,
I hope you're doing well. Before going to print, go to the selection filter and disable component selection. You'll see the crosshairs go away.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
LukasDebe
yes that worked.
Thanks for the help, I was spending way to much time trying to find a solution
Best Regards,
Lukas
