Printers not listed
Printers not listed
m_walczak
Message 1 of 27
Printers not listed
m_walczak
I have three printers, one that is local the other two are on the network, I want to print a schematic, but when I go to select a printer none are listed.  When I try to create a pdf by selecting "print to file(pdf)", I can't select it. Any thoughts on what the problem is. I have tried to restarting my computer and Fusion but that didn't solve the problem.
Mike
Replies (26)
Message 2 of 27
RichardHammerl
Hi @m_walczak
thank you for your participation in our Fusion Electronics Forum.
The print dialog should list all available print options. What is the operating system you are working with?
On my Windows 10 (German locale) the Print dialog looks like this:
Do see a similar situation with other application?
Thank you and regards
Richard Hammerl
Message 3 of 27
m_walczak
I see the print dialog, but all it has in it is the create a file PDF and that doesn't work either.  I have included two screen captures, one from Fusion the other from Adobe.
Mike
Message 4 of 27
m_walczak
Message 5 of 27
RichardHammerl
Hi @m_walczak
thank you for the images you posted. I see you are working on a Mac and there it seems to be a problem. I will report this to our dev team.
In the meantime you could print to PDF and then use the PDF viewer to print out on your printer. This worked on my Mac computer.
Thank you for bringing this up.
Richard Hammerl
Message 6 of 27
m_walczak
Thank you for getting back to me.  I have tried to save to pdf, but unfortunately I can't select it. When I do select it the listbox goes blank and the pdf window never opens.  Things seem to be unstable, I have had things work then stop working and not work then start other things just don't work, like this.
Message 7 of 27
TurningE
I have the exact same problem. Any solution yet?
Message 8 of 27
m_walczak
NO, they told me to print it to a PDF and then Print the PDF.
Message 9 of 27
TurningE
That does not work either. I get a message "Info canceled’. The set up screen looks fine to save as a PDF.
Message 10 of 27
m_walczak
R U on a Mac or Windows box?
Message 11 of 27
TurningE
Mac, sorry I forgot to tell you.
Message 12 of 27
jorge_garcia
Hi @TurningE ,
I hope you're doing well. The issue has been reported and is open. Printing to a PDF should be functional, could you try with a different design? I want to see if perhaps this is limited to the design you are working on.
Best Regards,
Jorge Garcia
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 13 of 27
TurningE
Jorge,
First, thank you for your excellent videos, they have helped me a lot but I guess not enough to get print to work. I am new to ECAD. To me laying out a PCB was black crape tape on mylar. That gives you a clue that I am 79 years old.
Anyway, I tried printing with a completely different schematic from a different project and got the same results.  I attached a screen shot so you might see what I am doing wrong.
Jim
Message 14 of 27
jib_ray
Community Visitor
Community Visitor
I have exactly the same symptoms: no printers show up in the Printer selection box and when trying to print to PDF I get an Info window saying "Canceled" after I hit the OK. I am running Mac OS 11.1 and Fusion 360 2.0.9512.
Message 15 of 27
m_walczak
Hi, it is a bug in Fusion.  Autodesk has duplicated the problem.  So, until the fix it we are stuck with creating PDF’s.
Message 16 of 27
RichardHammerl
Hi @m_walczak  and @TurningE
what is you Mac OS version? I see that @jib_ray uses Big Sur. You both too?
I'm just curious, because I am on Mac OS 10.15.7 and I can print into PDF....
Print dialog and PDF outputPrint dialog and PDF output
Thank you and best regards,
Richard Hammerl
Message 17 of 27
m_walczak
H, I can print into PDF with both Big Sur and High Serra.  That is not the problem, the problem is printing to a printer directly.  As mentioned, this has been confirmed by Autodesk as bug.
Message 18 of 27
cyberreefguru
I have exactly the same problem - I can not print to a printer or print to PDF - I get the cancel window. Is there any fix? This is such a basic function and it has been inop for months now.
Professional PowerPoint Jockey...
Message 19 of 27
m_walczak
There is no fix.  Autodesk has confirmed it that it is a bug.  The work around is to create a PDF and print the PDF.  I agree this is something that should not happen.
Message 20 of 27
m_walczak
Autodesk where are you on this problem?  When working on schematics, printing is something that you do quite a bit.  I reported back in October of last year.
