Polygon shape
Polygon shape
asprakash83
Polygon shape
asprakash83
When I try to make a polygon shape in design, I can't be able to assign net in polygon shape & I can't be able to see the property even though it is licensed version. Do anyone know what's the problem?
constantin.popescuXD3CL
Hi @asprakash83,
From what I can see from the snapshot you sent it looks like you haven't used the correct command Polygon Pour, please see below snapshot:
If you use that command then at the end of the coppr pour placement you'll be asked to provide the signal that owns the copper pour.
I hope this helps.
Kind regards,
Constantin Popescu
Principal Software Engineer
asprakash83
 When I use polygon pour, I can't be able to fully cover the region with copper. that's the reason I need want to use polygon shape tool, but I can't be able to assign net name for it. Here I have given a pic show gapes the copper area. What is he solution for.
Radiosonde v110_ (Ethics Tech Team) - Autodesk Fusion  03-12-2024 11_07_34.png
jorge_garcia
Hello @asprakash83 ,
The polygon pour tool is the one to use when dealing with copper layers as is the case here. Polyshape only works for non-copper layers. The polygon pour tools will let you draw whatever shape you want, in this specific scenario I notice you have lots of strange polygon shapes. The clearances in your rules can interfere with how the polygon fills so make sure you have them set to allow the polygon to fill and connect.
Some users will recommend manually connecting all of the pads before relying on the polygon to make the connections.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
asprakash83
Thank you for your guidance i have solved the problem
