Pick and place does not include through hole components
fusion3608TH2K
Message 1 of 13
fusion3608TH2K
As the title says. The cam output doesn't include any through hole components. The manufacturer is asking for them, so I assume it is something that should be generated but there are no options in the cam output. My current workaround will be to just manually type them out. Has anyone run into this issue?
Replies (12)
Message 2 of 13
engineeringNCMXB
I wrote my own ULP years ago to control output for PnP. We used part ATTRIBUTES to control how they are output.
Sadly, this is/was not a trivial process that required some effort to learn the ULP system - which is now different inside of Fusion360.
Carlos Acosta
Factory400 - YouTube|Instagram
Message 3 of 13
phaggren
I had this same issue just now.
Manufacturer contacted me saying that there are parts missing from the Pick and Place file.
I checked and noticed all the through hole parts are missing. Got about 300 SMD parts and only two through hole parts. The parts in question are tiny through hole connectors but they would be placed with the SMD part.
I also ended up manually typing them in. I could not find a way to include them in the CAM.
@jorge_garciaIs there any workaround this or could we make a a feature request for this?
Cheers!
Message 4 of 13
jorge_garcia
Hi Guys,
I hope you are all doing well. We ship with multiple pick and place ulps. The mount-smd-tht.ulp will export the pick and place information including the through holes.
No manual editing necessary.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 5 of 13
mohammed.hossein
Where to find the exported file? I could not find it.
Message 6 of 13
engineeringNCMXB
It seem that ULP file outputs are placed in a deep dark corner of the local disk.
@jorge_garciacan you specify locations or invoke a save-as dialog with a ULP?
Carlos Acosta
Message 7 of 13
mohammed.hossein
Message 8 of 13
meetudiii
How to use that _mount_smd_tht.ulp file? how to run it after I have downloaded it.
Message 9 of 13
p_zarzycki
Observer
Observer
In Fusion360, in PCB project, you have to go to [AUTOMATION] tab and select [Run ULP] in [Automation] menu.
Find mount-smd-tht script and run it.
The one is the most recent Fusion version does a good job and asks for a destination.
Cheers,
P.
Message 10 of 13
lobetrotter
Observer
Observer
Why hasn't this been fixed yet?
Message 11 of 13
Evert_2N3055
Can you explain Why hasn't this been fixed yet? making p&p file works for me.
Smd and Th file (csv) is generated in a directory of choice.
Message 12 of 13
m.ensing2UAQJ
@jorge_garciaIs there a way to change the ULP used in the CAM generator, for another one?
Message 13 of 13
jorge_garcia
Hello @m.ensing2UAQJ,
I hope you're doing well. Unfortunately, it's not possible to change what ULP the CAM generator uses for pick and place. If you want the pick and place that includes the through-hole components you have to run the ULP.
I'll add your comments to the existing request for a better pick and place in the CAM processor.
Best Regards,
Jorge Garcia
