@dieter.menne wrote:
Could someone confirm what @kb9ydn wrote: Managed is two way? I never see any changes from revisions show up in Fusion.
Even after you create the new version on library.io there are a couple more steps to do to get Fusion's designs updated. First you have to tell Fusion to use the updated version of the library on library.io. When you open the library manager in Fusion it will scan the managed libraries for updates and show you that updates are available.
After you click the update button Fusion will then use the updated library version for any newly inserted components. By design, components already in any existing schematics will NOT be updated unless an additional step is performed. Under the library tab in Fusion, there are two buttons called "Update design from library" and "Update design from all libraries used". The first allows you to update all components in a schematic that originate from a chosen library. The second will update all components in a schematic that have updates from all used libraries.
And that should get your schematics updated with the new libraries. Note that at the moment I have yet to try any of this with PCBs, so it's possible there may be bugs with synchronizing packages and footprints.
C|
