Package generator produces invalid geometry
rick.zrostlik
rick.zrostlik
I am trying to generate a polarized capacitor using the 'Radial Generic' Package Generator which I call from within my library. It generates a weird slice of the capacitor instead of the radial package that I am expecting. I have confirmed that this happens if I used the default parameter values or try using values for my specific cap that I am interested in.  Please see my screencast for an example when using the default parameter values.  Any idea if this is a bug or am I doing something wrong?
Rick
jorge_garcia
Hi @rick.zrostlik,
I hope you're doing well. I thought this issue was fixed. The cause is actually the units, if you switch to metric you'll see that it forms the capacitor correctly.
I'll report this to make sure it gets addressed.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
rick.zrostlik
Thanks @jorge_garcia
To be clear, I had to set the default units in the preferences to be in mm. Just using mm in the package generator dialog box without changing the default units still caused the bad geometry. Is this consistent with your understanding of the issue?
Rick
Rick
jorge_garcia
Hello @rick.zrostlik,
I hope you're doing well. It is consistent with our current understanding of the issue, sorry that you ran into it.
I'll report it.
Best Regards,
Jorge Garcia
