Package generator confusion density level
jimUR4RG
jimUR4RG
Just a small thing but the Density level in the Package generator (specifically the SON generator, but maybe others as well) seems to be inverted.
When Density Level is set to Most, I would expect very small pads, so I can put many chips on my board (high density). However, the Higher the Density Level is set, the larger the pads become. This is a bit confusing.
Kind regards,
Jim
phaggren
Hi Jim!
Those words is based on the IPC standard so they are same across the board with others EDA's and manufacturers.
I agree they are bit confusing.
Not the most scientific way to put it, but this is how I always think of it.
Least:      Takes the least amount of space (0402, BGA decoupling caps etc.)
Nominal: Takes the normal amount of space
Most:      Takes the most amount of space (easier hand soldering)
Cheers!
Petri
jimUR4RG
I didn't know that, thanks for the clarification!
