- Mute
- Permalink
- Report
Hey guys,
Well, I'd like to start with a positive note: This new electronics integration would be great.
Having said that: Would be, because since the new version I barely have been able to do any work. It actually feels like I'm alpha testing the software. I'm not, and I actually need work done!
So I'll list a few of the problems I'm having now:
1. Constant crashing.
Whether it's switching from board to schematic, or simply editing a package, at random times Fusion 360 will just crash. I get the opportunity to enter what went wrong and send a report. If anyone is reading any of my reports: sorry for my language: I was very frustrated 😉
2. Error messages/warnings
This happens often and it happens at seemingly random times (I know there's no such thing). They all have in common that they provide very little information about what went wrong. Just now I got this:
"Warning: The PCB document isn't working in an electronics design."
If I understand this correctly, this means that the board (is that a PCB document?) I'm working on is no longer a part of (in?) an electronics design. Well, it was just before. I even opened it via the electronics design and I see no reason for it to not be "in" it anymore (I hope just closing the Electronics design did not cause this). Is this really a problem? No solution provided here. Also, clicking more info just gives me the exact same error message in a different view.
I feel I get loads of warnings and error messages, even when I didn't change anything. I didn't write them all down but I'm now trying to keep a list.
3. Constant warnings of board inconsistencies
This already happened in Eagle but it seems it now is not only more frequent but also harder to solve.
4. Versions, versions, versions
Every change I do increases the version number. Not only that, but if I change something in, say, my library, I have to save the change (for instance a package, V++), save the library (V++) and then also all documents that depend on this library (V++). That means that all document a one-up on their version number and I have to type in the change comment for every one of them. This seems a bit unnecessary.
5. Changes in library are not always visible (more often not)
This is for me a hard one to describe. I have no clue what's going on here. It seems that I first need to upload my existing Eagle library to the cloud and then replace all components to use the new library.
When that's done, I want to add a 3D package to the library. I can't really figure out what's going on there. A change in the library forces me to save my electronic document (board, schematic), yet the library version number of the components lags behind (My library is now at V9, yet in my board and schematics, some are still at V4 with no option to update that). Now, when I want to see the new 3D packages in the 3D board, I click "View 3D PCB" (with or without canvas, result is the same). I would expect my 3D packages to show up but for some reason they sometimes do and sometimes don't (they more often don't). I still haven't figured out what I'm doing wrong but in my opinion this is a flaw in the workflow (this should be easy).
6. Sluggishness
Although the last update has helped a bit, the software stays sluggish. Especially the electronics part. I never had any performance issues in Eagle or Fusion 360 when they were separated but now I often have to wait minutes before something loads (and then often it crashes).
So, all in all, I'm not a happy customer. This whole endeavour has been very unsatisfactory and I'm mostly frustrated that I have already have a whole week of unproductiveness.
I hope that in newer updates these issues will be addressed or that maybe someone here could give me some pointers as to how to fix or avoid them.
Sorry if I come off a bit negative but I hope this can help the Fusion 360 team to get some user insights too.
