Misplaced hole in CAM Processor Image preview
mike.durian
mike.durian
I have the CAM processor configured to generate PDF images of both the top and bottom of the board. My board has one non-plated through-hole for a mounting screw. It appears correctly in the top view image, but not in the bottom view. The hole outline is in the correct location, but the drill marking is offset. At least in the preview.
The actual PDF containing the two views show the top correctly and while it does not show a misplaced marking in the bottom, it doesn't show any drill symbol at all (no circle with a bar through it). Perhaps it is only supposed to show up in the top view?
Not a huge problem, but I thought I'd mention it.
Top preview
Bottom preview
PDF output
jorge_garcia
Hi @mike.durian ,
I hope you're doing well. It seems odd to me that the bottom board is rotated by 90 degrees. I wonder if that has something to do with the drill marker being off center. Could you double check if you have any of the rotation settings active in that particular section?
Would you be willing to share the files for review?
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
mike.durian
Hi @jorge_garcia ,
I hope you're doing well. Yes, I do have mirror output horizontally option selected. It seems more intuitive to me. With it selected, the image will match what you see when looking at a physical board.
Yes, I can share these files.
mike
Closed-Loop-Bot
Thanks for bringing this to our attention. We're investigating the issue, and you can reference ticket FUS-248268 when communicating with Autodesk to find out more. Once the status of this will change, there will be a follow-up forum post made.
