Managed library import failed (failed).
js4851
js4851
When trying to push my electronics library to the server, I get the following error:
If this problem persists, please contact technical support and include the library URN
Any ideas? I made some changes to the library on the server side.
jesper8W75R
Welcome to the wonderful world of cloud computing.
I have seen this more times than I want to remember.
The solution: Don't use managed libraries. Unlink everything completely from Library.io.
Just use the Team Hub.
rnd_tr1
Even if you unlink, bugs still continue.
Asks time by time if you want to "merge!" libraries with team one, local one and .io one.
On some places you can call only .io one, not from team hub...
And now with latest march update, I can't even submit changes properly on team too.
js4851
Thanks - can you provide more details about how you would use the team hub? Just share a library there and link to it? I do have another collaborator who is remote.
jorge_garcia
Hi @rnd_tr1
Could you describe what you are running into more specifically? I don't know if it was you but we had another user bring this up and that's when I really understood the subtle issue you are running into. I believe @jesper8W75R has also run into a version of this.
Basically, right now it takes a lot of work to fully unlink a Team library from library.io. Even if you break the link at the library level the links at the individual 3D model level are still preserved. In order to fully break it you have to go into each individual 3D model, edit and assign new models to them. Our team is aware of this pain point and it's on the roadmap to provide a formal, easy way to fully schism the team library and the managed library from each other.
Any additional info will be welcome and will help us figure out what's going on.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
