- Mute
- Permalink
- Report
In order to get consistent work flow for my team of 4 engineers, we've migrated all of our electronics parts libraries from Library.io to Fusion Team libraries, mostly this seems to have worked, and it has greatly improved the speed of processing the 2D->3D conversion.
Unfortunately, the linkage between Library.io and the current Fusion Team library does not seem to want to go away regardless of how many times we select "Unlink from managed library on library.io". Every time you open one of these library, the link is silently restored, and attempting to unlink causes Fusion to think the LBR file has changed and needs to be saved again. This can be problematic because it is not clear what exactly has changed, accidentally allowing an "update" from the now obsolete managed library causes loss of work, which can be fixed by 'reverting' the library to the correct most recently saved Team library, but now the library version number has to be updated again to overwrite the incorrect 'latest' with the correct 'latest', and as soon as you close the library, the stealth linkage to the managed library will re-appear, generating yet another opportunity to mistakenly allow the file to be regressed.
We would just delete the managed Library.io objects entirely, but there are a handful of 3D models for packages which apparently dont exist in the Fusion Teams library, and are being pulled from Library.io during 2D->3D conversion, although which ones are in this state is not visible until you open the package itself in the library editor, whereupon a dialog pops up "The references package is not stored in Fusion Team. Do you wish to copy the package to Fusion Team and update the reference". Even after doing this however there appears to be residual meta-data linking to library.io as you can open the library (with the now ghostly linkage reappearing) and drill down to the 3D package and look at the attributes, there's still a "View on Library.io" link present.
This is impacting serious design work - we have libraries with thousands of parts, manually opening each one to find un-ported 3D packages is untenable, but leaving these links and risking continuing regressions also means some 3D models of PCBs are inaccurate leading to failures during PCB-to-enclosure assembly, and PCB-to-PCB mating. Has anyone successfully broken links to old managed libraries or is this an intended "Feature"?
