- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a variation on the analog ground / digital ground question. As answered in the Eagle forum, I know you can join an analog ground and a digital ground using either a 0 ohm resistor or by overlapping separate polygons and ignoring the warnings. Neither of these solutions quite address my issue.
In my case, I have a power ground area I'd like to keep separate from a regular ground fill on the top layer, only joining them by dropping vias from the power ground to a middle ground layer. Since I'm only joining grounds by vias, the 0 ohm resistor and overlapping polygon tricks won't work for me.
Since I'm using vias to connect power ground to regular ground, I need to keep both signals named GND (as opposed to GND and PGND, say). Ideally, I'd like to make my power ground polygon rank 1 and then my surrounding, top layer ground fill rank 2. If the signal names were different, my power ground would be automatically isolated from the surrounding ground. However, the names are the same and fusion will join them. Is there a way to trick Fusion in treating the two polygons as the same GND signal, but keeping them isolated from each other? Perhaps by naming them GND@1 and GND@2 or something? I suspect not.
My next thought was to draw a line in the tRestrict layer to cut out my power ground area. Basically, make a moat around the power ground area. This actually works, but I have to set isolate to zero in the large ground fill polygon. With a non-zero isolate, I get additional gap around my tRestrict lines. If isolate is zero, then the regular ground polygon bumps up against the DRC limits around other signals. I have my DRC value low to handle a couple, isolated cases, but in general want a larger isolate value for most of the ground polygon.
The last option I can think of is my least favorite. It is similar to drawing a line in the tRestrict layer, but instead, I create a moat using a number of cutout polygons. Creating the moat from a bunch of polygons is an awkward process and it appears that the cutout polygon type isn't even an option in Fusion, so I'm not sure this is even a viable option.
So, does anybody have a good solution for this scenario?
