Is there a way to add spice parameters from schematic to the netlist?
OyvindWetteland
OyvindWetteland
I wish there was a schematic symbol named .PARAMS where I could add various parameters to the simulation netlist.
When I carry out a spice simulation in a Fusion 360 Electronics design, I can see that there is a separate section in the netlist with the heading:
* --------- .PARAMS ---------
For now, this section is completely empty.
Is there a way I can add parameters into this section?
I need this functionality in order to pass parameters to my spice models.
edpataky
Hello and thank you for the question .. this is how you do it:
1) place a text object in the schematic anywhere and set its text to ".PARAM"
2) after the first line, add variable=value on each line after that, one per variable
Attached is an example for transformer ratio sent in as a parameter ".PARAM" on the first line and "RATIO=20" on the second
The model mapped to the transformer part looks like this:
* Autodesk EAGLE - Spice Model File
* transformer subcircuit, requires RATIO parameter defined
* Date: 10/1/17
.SUBCKT XFORMER 1 2 3 4
E 5 4 1 2 {RATIO}
F 1 2 VM {RATIO}
VM 5 6
RP 1 2 1MEG
RS 6 3 1U
.ENDS XFORMER
Notice how to the variable is in braces.
That's how you do it!  Let us know if this solves the issue.
OyvindWetteland
Yes, this solves the issue.
A very easy and practical solution 🙂
