is it possible to change outer and inner layer diameter of via manually?
TS02225217
TS02225217
I need to decrease outer and inner layer diameter of via. is it possible?
m.neujahr_at_moe
Hello @TS02225217 ,
you can change the diameter in the DRC-Dialog:
These settings are for all vias (pads or micro-vias) that have "auto" in their properties for "diameter".
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
vitalmobil
Community Visitor
Community Visitor
Mine is stuck at 25.59055 mil, and cant lower to 9.84252 mil.
I tried to change annular ring, i changed diameter to auto, nothing helps..
jorge_garcia
Hello @vitalmobil ,
The annular ring settings will win over anything you set manually. So it's important to adjust the annular ring settings to whatever your board house can actually do. Remember that the drill value will always stay to whatever you set it but the diameter value is always subject to the annular ring settings.
See this article for a full explanation of the annular ring settings.
https://www.autodesk.com/products/fusion-360/blog/what-you-didnt-know-about-eagle-restring/
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
