Insert a schematic or Insert an electronic design into a schematic
m.s.uludag
m.s.uludag
Quickly explaining,
Here it explains how it works.
https://help.autodesk.com/view/fusion360/ENU/?guid=ECD-INSERT-DESIGN-SCH
  1. On the Schematic Design toolbar, select Place > Insert Electronic Design msuludag_0-1676974976691.png.
  2. In the Browse dialog, navigate to and select the design to insert. The design schematic is attached to the cursor.
  3. In the canvas, position the schematic and click to place it. The imported design schematic sheet is added to the current schematic document.
It was working as explained in steps 2 and 3, but now every time I try to insert a schematic or an electronic design into my schematic, it just creates a new SHEET adds it there automatically, before it was placing it on the active sheet (I was able to combine multiple designs).
Can you tell me how to overcome this issue? Is there an extra option I activated/deactivated without knowing?
yqliu
@m.s.uludag , I think it's because the schematic to be inserted has multiple sheets. Can you check it?
m.s.uludag
@yqliu , thank you for the quick response.
I just checked again, Schematic to be inserted has only one sheet. Both of them are one sheet.
yqliu
@m.s.uludag , I just confirmed this is a bug of the application (This issue is internally logged as FUS-98786 for the team's reference).
m.s.uludag
Okay, if it is possible could you let me know or is there a way to add the issues to our watchlist so we can track ourselves?
yqliu
Sure, we will let you know.
