Insert a copy to current design
duVX7Q3
duVX7Q3
In importing 3d models, I do the following:
1. Download step file from website/manufacturer. Upload this step file to our fusion team.
2. In content manager, I click "Create New 3D model". This creates a placeholder for the footprint I made (drill holes/pads for example)
3. While the newly created 3d model from step 2 is open, I will open the data panel and find the 3d model I downloaded from manufacturer.
4. I will insert the downloaded model into my created 3d file.
5. I will simply move the inserted component with respect to the placeholder/footprint.
6. I no longer need the downloaded file so I want to delete the file from step 1.
7. I break the link to the downloaded file.
8. I saved my 3d file.
9. When try to delete the downloaded file, it still says it is referenced.
Any way to fix this?
I don't want to keep two 3d files (downloaded and actual footprint + component) for each part in our library.
jorge_garcia
Hi @duVX7Q3,
I hope this message finds you well. For now you have to keep both 3D files. It's the nature of the beast at this time and a known limitation.
I'll add your concern to the existing tickets on this.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
