Firstly, I have to say I'm very impressed with what I've seen so far. As a long-time EAGLE (20+ years) and Fusion 360 user, seeing this come together in a unified way is awesome.
I have a large project that's about to start within the next few weeks. It will involve some new board designs as well as the reworking of about 20 existing board designs. In almost all cases, these boards will require front panels and will need to fit together into multi-board assemblies in some cases, so this seems like an ideal use for the new capabilities.
I had a play around today, but hit some issues. Though I was able to import existing boards, schematics and libraries, once in the Fusion world they were no longer linked together. Specifically, I had a design done just a week or so ago in EAGLE which had a completed schematic and a mostly complete board layout. After the import, the board and schematic were no longer linked.
As a second issue, the imported libraries were older (unmanaged) libraries, but I do have a need to generate accurate 3D views because this will be necessary for accurately designing front panels with appropriate holes and slots.
What's the best way forward here? As a side-note, I'm OK with redoing the board layouts because I'd intended doing that for design-for-manufacture purposes (and to correct some EMC issues left over from an older design). Do I need to replace the unmanaged libraries by making new ones? Advice appreciated!
One other question -- what's the likely longevity of the separate EAGLE software from the point of view of being able to maintain older designs? This is a separate question, but might be the same question if the answer is to stay with EAGLE.
