How to use .dwg PCB Layout file set properties (thickness and line naming)export ODB++
Zachary_wu
Observer Observer
Zachary_wu
Observer
Observer
I need to use the manufacturing in fusion to create a new PBC to export the ODB++ file to ansys Q3D for simulation analysis, but I need to set the properties of the pcb layout diagram first (such as thickness and line segment naming), but I cannot successfully export the required ODB++ , there is no thickness or line segment naming in the file. In addition, I directly tried to load the .dwg for settings, but there was no way to successfully convert back to the ODB++ required for PCB output. Is there any user who has relevant experience to share? Thank you.
jorge_garcia
Hello @Zachary_wu,
I hope this message finds you well. DWG files don't carry the data necessary to make a proper PCB. You can import some geometry from a DXF file but all of the setup needs to be done inside a proper PCB design tool. Fusion Electronics can help you setup the parameters you need. From there you'll be able to export to ANSYS tools no problem.
Here's a playlist to show you how you get your first design finished.
https://www.youtube.com/playlist?list=PLmA_xUT-8UlL80Xm8Gxz98YNum3I9GInr
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
