How to create a library from schematic
yaqoubdesign
Message 1 of 53
yaqoubdesign
I have a schematic with components/packages/devices that come from separate libraries, and I would like to create a separate library with only these components, for use with student projects. I see there's a video tip that explains this for Eagle (https://www.youtube.com/watch?v=3Un_Z0kis6c). In this video a ULP is used to do this. We are told to use "exp-lbrs-replace2.ulp" . I tried this in Eagle but I get a lot of errors. My plan was to create the library and then use it in Fusion 360 Electronics. What's the best way to do this? Can it be done in Fusion 360 Electronics?
Replies (52)
Message 41 of 53
jorge_garcia
Hi @LloydTravisSmith ,
That's not the right place. In the upper portion of the screen you'll see a bar that says click to type. That bar is to the right of the grid spacing and cursor position fields. Click in that field and type EXPLIB there. See screenshot
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 42 of 53
LloydTravisSmith
OK, confusing that there are two places to enter text command, but I tried
it and it worked. Thanks
Message 43 of 53
panpan_fan
Hi @LloydTravisSmith  @yaqoubdesign
I hope you are doing well!
Todya we release Fusion 360 V2.0.12157 and now you can see the Export Libraries command in the menu bar.
Panpan Fan
Message 44 of 53
LloydTravisSmith
Great news. Thanks for the feedback! I was able to make a library by exporting to Eagle, but it will be important to be able to skip the Eagle step going forward.
I feel like I have been able to get my mind around most aspects of Fusion360 Electronics, but I am still dogged by libraries. I have been creating libraries according to the instructions Jorge Garcia gives at https://www.youtube.com/watch?v=2Os1RZU1ZgM, but I think the workflow and user experience need to be streamlined significantly for someone with my skill level to be able to feel confident with it.
Message 45 of 53
jesper8W75R
@jorge_garcia
I know this is an old post.
But still, without it, I wouldn't have know about the EXPLIB functionality, which I needed.
Because it is not documented ANYWHERE!
Certainly isn't in the CLI reference:
https://help.autodesk.com/view/fusion360/ENU/?guid=ECD-CLI#e
And not available from any menu or anything.
The only other place it is mentioned, apart from this post, is in a "December 2020" Product Update.
Seriously?
How many other useful command exist, which you have not documented?
Will there EVER be a Fusion Electronics manual, that actually is up to date and contain proper documentation?
Message 46 of 53
jorge_garcia
Hi @jesper8W75R ,
I hope you're doing well. Like I mentioned in another post, the documentation is being worked on and it will start to really improve from release to release moving forward. I don't think there will be a paper manual as such but Fusion 360's online documentation will eventually fully satisfy that need.
Best Regards,
Jorge Garcia
Message 47 of 53
jesper8W75R
@jorge_garcia , I'm happy to hear you're working on it.
But, sadly this is what I have become used to hear from Autodesk.
And considering that the original post is from July 2020, I would say it's about time you get this command documented.
While we wait for you to "work on it", would it be possible to just get a list of "unknown" commands like explib?
I don't think anyone expects paper manuals anymore.
Message 48 of 53
dev2EP8UX
Has the question of @cmot17 ever been answered?
Message 49 of 53
dev2EP8UX
@cmot17 wrote:
Hi, this solution seems to work for exporting the library. However, it seems like all of the parts in the document still are referencing the old library which I don't have, so I would have to manually replace each part.
Any way that I can automatically fix this or at least do it in bulk?
has this question of @cmot17 ever been answered?
Message 50 of 53
jorge_garcia
Hello @dev2EP8UX,
I hope you're doing well. This was actually already addressed using the Swap libraries command. I'm actually due to make a video on that. I'll try to get to it after AU.
Best Regards,
Jorge Garcia
Message 51 of 53
dev2EP8UX
Thank you!
Message 52 of 53
yaqoubdesign
Panpan,
I just tried using the export library icon on the menu bar and nothing happens.  If I type "explib" in the command line interface,  then it works.  Is this just me or is it a bug?
Message 53 of 53
panpan_fan
Hi @yaqoubdesign
The Export Libraries icon works well for me.
Would you mind using other schematic files to check? Thanks!
Panpan Fan
