How to create a Design Block
SebastianE123
Message 1 of 15
SebastianE123
Hey,
I just saw that there are Design Blocks for Fusion360 Electronics since the last big update.
I'm familar with creating and inserting these Design Blocks in Eagle 9.
But I did not find how I can create my own new Design Blocks in Fusion360. I only find how to Insert a existing one.
Can anyone help?
Replies (14)
Message 2 of 15
HelenChen-AutodeskQA
Hello @SebastianE123 ,
Thank you very much for asking.
For Design Blocks in Fusion 360 Electronics, so far we only have insert Design blocks function, but no create Design blocks function in Fusion 360 yet.
But as a workaround, you could choose to save or export the design (sch/brd) or multiple select assets and then copy to a new sch/brd file to save or export them, and then use Insert schematic / Insert board file instead.
Hope it helps.
Hope you have a great day.
Best regards,
Helen
Helen Chen
Principle QA for AutoCAD Windows
Message 3 of 15
SebastianE123
Thank you for your fast answer. Yes it helps.
But now im wondering.
When there is only the Insert Design Block function yet. How you can insert a Block if no one can create them? Or do I miss something?
So someone has to create one in Eagle 9 and you can insert it in Fusion?
Message 4 of 15
Hi @SebastianE123 ,
Yes, in Fusion 360 Electronics, you could reuse the design blocks created in EAGLE. Just select the design block file from local computer, then you should able to reuse them in Fusion 360.
Hope it helps.
Best regards,
Helen
Helen Chen
Message 5 of 15
pblase
How long until this is fixed?
Message 6 of 15
deepak_elango
Hi @HelenChen-AutodeskQA
Now is there any provisions to create a design block from a part of circuit in schematic?
Best Regards,
Deepak Elango
Message 7 of 15
jorge_garcia
Hello @deepak_elango,
I hope you're doing well. The Designblock authoring functionality is not available in Fusion, we are reworking it in order to provide a better solution that doesn't have the issues that designblocks suffered, namely when you have nets the go beyond your selection the block functionality didn't handle them correctly.
For now in Fusion, the solution is to take that circuit piece and save it as its own electronic design. You can then insert that electronic design in new designs.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 8 of 15
tomhughes5XEES
Community Visitor
Community Visitor
@jorge_garcia
Can you please confirm that the above post is still the current state of play please, I am currently using Fusion 2.0.20981 version. ie does fusion 360 still not support design blocks?
Message 9 of 15
jorge_garcia
Hello @tomhughes5XEES ,
I hope you're doing well. Yes my response above is still the current state of play. You can consume designblocks but you can't create them.
Best Regards,
Jorge Garcia
Message 10 of 15
pblase
I would definitely encourage a solution, and soon. I am currently having to have a second rev of a board made because of a connector mismatch between it and a daughter card. There's no way in Fusion to ensure that the flow through the mezzanine connectors is correct between boards, you have to verify it manually. Also, since the motherboard has 4 identical daughter cards, I had to lay everything out four times on it.
Message 11 of 15
jorge_garcia
Hi @pblase,
I hope you're doing well. You can avoid the duplication of effort by drawing the daughter card as it's own electronics design. Then you can insert the electronics design 4 times into your top level design. The layout will be preserved and you can avoid the duplication.
That's the recommended solution for now.
Best Regards,
Jorge Garcia
Message 12 of 15
tomhughes5XEES
Community Visitor
Community Visitor
@jorge_garciathanks for your feedback a couple of days ago my manager is asking do you have an indication of when the full design block functionally is likely to be added to fusion 360? ie creating and consuming design block functionally?
Message 13 of 15
jorge_garcia
Hi @tomhughes5XEES ,
I hope you're doing well. The current decision is that the Design blocks will be replaced by a feature that can encompass it's functionality and more.
So as of right now, there's no intention of re-implementing design block creation. I will pass these comments up the chain, who knows maybe it can change the decision.
Best Regards,
Jorge Garcia
Message 14 of 15
tomhughes5XEES
Community Visitor
Community Visitor
Thanks @jorge_garcia do you have a timeline for the feature in 360 which will replace design blocks?
Message 15 of 15
jorge_garcia
Hello @tomhughes5XEES,
I hope you're doing well. Unfortunately there's no firm ETA at this point. If I had to venture a guess it's more than a year out.
Best Regards,
Jorge Garcia
