How do I rotate (and place) components using a script?
user9421445
user9421445
Hi there,
after trying and searching for quiet a while im not able to figure out how to place components at specific coordinates including a rotation via a script/command on a pcb.
Background: I want to place a bunch of objects in the right place using a script. The exact locations are calculated using an excel sheet (not the best way, but it works - lol).
Using the MOVE command im able to move them to the right x,y but im probably not smart enough to rotate them.
Has anyone faced the same problem and found a solution?
Im grateful for any help, maybe im just missing the right syntax.
jorge_garcia
Hi @user9421445,
I hope you're doing well. In addition to the MOVE you can add a line to the script that says
ROTATE =MR(degrees_of_rotation) 'RefDes_of_Component_to_Rotate'
That's all you have to do.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
user9421445
Thanks!
