How do I create a custom shaped SMD pad?
g.taylor.3
Message 1 of 14
g.taylor.3
I want to create a new sized SMD pad - dimensions in mm. How do I go about doing this? I have found some tutorials for doing it in Eagle but nothing is quite the same anymore.
Any help appreciated.
Thanks.
Replies (13)
Message 2 of 14
edwin.robledo
Hi  g.taylor.3,
I hope all is going well, thank you for participating on the Forum.  In the Fusion 360 electronics library editor open an existing library or open a new library editor session.
With the library open, click on the grid command and set your grid to mm.
With the grid selected. Use the SMD command to add a pad. Before placing the SMD pad, make sure you select the correct size from the drop box, or double click the size field to add one.
If you need an arbitrary shape, draw a polygon on top of the SMD pad. Make sure to duplicate the polygon and change the copy to the corresponding Stop layer.
Let me know if this helps.
Please 'accept as solution' if my reply resolves your issue.
Edwin Robledo
Tech Marketing Manager
Message 3 of 14
g.taylor.3
Pretty much exactly what I was after. Many thanks.
Message 4 of 14
What should I do if when I enter in the 'new electronics library' there are only the commands to create (device, symbol, footprint and packaging) and nothing else?
Thank you
Message 5 of 14
jorge_garcia
Hi @Anonymous ,
I hope this message finds you well. The order is in general not to critical but I would start with the symbol, then the footprint and the package. The device is always last because it is the glue that connects the other 3.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 6 of 14
erussellK6Q8Z
I'm not sure I fully understand the workflow you suggest, and I'm stuck on this part of the interface. I'm just starting with F360 Electronics, coming from Altium.
If I want to create a SMD pad for a thermal pad in the shape shown in the image below, what would be the best way to do this? If I understand correctly, you are suggesting to first make a pad with the largest dimensions  - 2.45 mm X 2.5 mm (where 2.5 mm is the width of the part along the side with the pins), then create two rectangles with the size of the cutouts and place them over the pad , and then copy each rectangle and paste into the Stop layer? Is this correct?
Is there not a way to create a more complex pad shape directly, with fewer steps? Or am I missing something?
Elizabeth
Message 7 of 14
jaowens14
Observer
Observer
Some clarification on this topic would be great. I have followed these and some other steps but I have not be successful. Jorge or Edwin would you be able to break down the process with a few figures? The first answer here was good but for someone like me with less experience its hard to follow.
Message 8 of 14
martinyoung1
As jaowens14 has said I am also struggling with this, are there any video tutorials to help?
I’m need to create pads for a small stepper motor which need to be in a specific pattern, they also need to be on the back of the board is this possible?
Message 9 of 14
mohdyaser3
Could you please elaborate more how to do a custom SMD, I want to do it to be like the image:
Is there any video or tutorial to explain how to do the custom shape?
Message 10 of 14
tattoome.eu
I need to add a custom pad to a PCB board. How can I do that? The one in the picture is inserted as a DXF. How can I make the name of this pad active and connect it to a symbol? I know I can add it to an SMD pad, but my custom pad will be made of polygons.
Message 11 of 14
jorge_garcia
Hi @tattoome.eu,
I hope you're doing well. The key to turning that into a pad is to add and SMD pad within the boundary of that polygon and then some additional polygons on the soldermask and stencil layers. See the documentation here for more details.
https://www.autodesk.com/products/fusion-360/blog/what-you-didnt-know-about-eagle-arbitrary-pad-shap...
Best Regards,
Jorge Garcia
Message 12 of 14
tattoome.eu
if I make a polygon from the outline - then the whole pod is under soldermask. You lose customers on this because, for example, in easyeda it can be done easily by problem - model your ergonomics on this program because it is fast and easy to use and gives a lot of possibilities
Message 13 of 14
jorge_garcia
Hi @tattoome.eu,
Thank you for the suggestion, that's why I gave you the reference for the arbitrary pad shape feature. You can't stop at just making the pad you have to make sure to draw in the soldermask and stencil features.
Best Regards,
Jorge Garcia
Message 14 of 14
tattoome.eu
please record a video on how to do it exactly
