How display the schemtic Net Class Rules in mm
anthonyEX9NB
anthonyEX9NB
There is a difference in the Net Class Rules between the schematic editor and the layout editor. In the schematic editor the Net Class Rules are shown in inches. There doesn't seem to be a way to change this to display in mm. However, in the layout editor the Net Class Rules are shown in mm. I want everything to display in mm. I just discovered this difference as I was typing out this question.
I expect this happens because in my preferences I have set the schematic default units to inches while the layout default units are mm. I keep the schematic units as inches because of the fact that when I started using Eagle it was highly recommended to keep the default schematic grid to 0.1 inches because all the library elements were designed on that grid, and nets wouldn't connect if I used anything different.
The question is, how do I display the schematic editor Net Class Rules in mm while still keeping the grid default
jorge_garcia
Hi @anthonyEX9NB,
I hope you're doing well. So you can set the Grid units to be whatever you want in the schematic 0.1" is equal to 2.54mm so go ahead and change the grid units you won't have any problems.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
