How are copper pours connected to other layers?
yaqoubdesign
yaqoubdesign
If I add a copper pour on my top layer (bottom layer is DGND),  and give it the same signal name (DGND):
1)  How does this  copper pour connect  to the DGND layer? I assume some kind of default via with some default spacing?
2)  If I want this copper to be exposed (no solder mask),  do I have to add a tstop polygon to the pour area?
mtl_asm
1) you have to add the via yourself. simply naming the pour will not automatically generated any physical connection. place a via then name it the same signal as the pour and it should connect to the 2 planes on each layer.
2) yes that should work.
yaqoubdesign
Thank you..
