- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, there is a bug: in the electronic design, it is not possible to highlight airwire (board routing) using the Show command. Airwire cannot be selected at all using the Show command.
Please correct it. Eagle did it perfectly.
____
One suggestion for improvement: it is much more efficient to use the 'Show @' command instead of the Show command. Can you add this as another button next to the Show command?
It is possible to define your own shortcuts for custom commands such as 'Show @'.?
