Hide/show pour poligons not working anymore after update
xpuipc
Message 1 of 12
xpuipc
i updated to 2.0.9636 and it seems that it is not possible anymore to hide/show the poligons anymore.
They are always there even i want to hide them via menu command (Hide poligons).
Thank you
Torsten
Replies (11)
Message 2 of 12
panpan_fan
Hi @xpuipc
I hope you are doing well!
For your issue, I test the Hide all Polygon Pour fills feature in the Fusion 360 V2.0.9636 and it works well for me.
Would you mind having a try again? And if you still can reproduce this issue, then please leave your comment, thanks!
Best Regards,
Panpan Fan
Message 3 of 12
rbkyorem
I cant hide polygon pour fills too.
Message 4 of 12
rbkyorem
So, again I found a workaround...
After changing some traces and pushing 2D design to 3D and returning back to my 2D design pour/unpour started to work.
But.... It will not work if you unpour and try pushing to 3D because it wont push to 3D....
I tried this on 2 different projects and this bug does not occur once I do the workaround. Have to do it on every project it happens.
Message 5 of 12
jorge_garcia
Hi @rbkyorem ,
I was able to reproduce this and I have informed the developers about this. We will look into this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 6 of 12
xpuipc
Ok, now after update today I have version 2.0.9640 fine...
Does this version tries to fix the problem with the pour polygones ? It is still the same, additionally Fusion crashes every time i push the 2D PCB to 3D (2 error reports were sent to you). I also tried to cut the 2D/3D link before, it has no effect, crashing also.
Thank you
Torsten
Message 7 of 12
jorge_garcia
Hi @xpuipc ,
This first hotfix doesn't solve it yet. There were some bigger Fusion issues that needed to go out. The fix will be out in either another hotfix or the next release.
Best Regards,
Jorge Garcia
Message 8 of 12
panpan_fan
Hi @xpuipc
After further testing, I find it is a regression issue for old files. And I have reported it to our developer team.
I will keep you updated when we fix it.
As a workaround,  you can remove the link between 2d PCB and 3D PCB. Then you can view 3D PCB again and Save a new version of Electronic Design, then it can work now.
Please have a try, thanks!
Panpan Fan
Message 9 of 12
xpuipc
Hi @panpan_fan ,
tried to push 2D to 3D, as mentioned before Fusion crashes (e.g. see report 300187659 and two others)...with different designs.
Torsten
Message 10 of 12
panpan_fan
Hi @xpuipc
I am sorry for the Crash issue.
Would you mind sending us your Electronic Design? Then we can track the crash issue more quickly.
I will send my email address to you as a private message. You can send your file to me if you are willing.
Panpan Fan
Message 11 of 12
phaggren
I have the same issue.
Can't hide the polygon pours. Also the whole design suddenly became really sluggish.
@rbkyoremworkaround solved the issue temporarily with the pours and the lagginess, soI  can continue with the design.
Message 12 of 12
panpan_fan
Hi @xpuipc  @phaggren @rbkyorem
Today we release Fusion 360 V2.0.9849. The Hide/Show Polygon issue should be fixed now.
Please have a try,thanks!
Panpan Fan
