- Mute
- Permalink
- Report
Hi all, i'm designing a circuit board with an atmega2560 chip which has 100 pins and no matter what clearance i put in the smd-smd section it will show clearance issues as well as can't run a net to these wires.
Any idea what may be causing this?
I have set the grid view to 0.15 ( same as clearance so you can see the pads are more than this apart ( approx 0.25mm)
But still get the error
Darcy
